Engine – Tick-Tick-Tick
Rephrasing as the sound is more like a Tap-Tap.
My 86 Carrera has an annoying ticking sound for a while now and thought it was the valve lash which was not. Double confirmed adjustment and the tick was still there. The sound generally is more noticeable when cold, but dissipates upon warming up, but it’s still there. At times when cold, the sound is almost non-existent. It appears to be on the passenger bank side. To make a long story short, when I installed the RSR rocker shaft seals on all shafts, I noticed that the exhaust valve on cylinder five had a slight lateral movement which all others did not and were a tight fit. The engine has approximately 220k miles on the clock with a recent rebuild at some point which I don’t have documentation for, but just the word from the PO. Oil consumption is very low (1 quart per 2,000k miles) or so. When I replaced the engine bay fuel lines and removed the plenum, I noticed that the heads were Mr. Clean clean with very little residue which confirms a rebuild at some point. I will be changing the oil and taking the exhaust rockers, shafts and springs to take another look. Appreciate any and all advice. Serge Last edited by nene; 10-17-2025 at 01:41 PM.. |
Exhaust leak? Sometimes mistaken as a mechanical tick...
I wish it was an exhaust leak, but I can say with honesty that it isn't.
A tick tick sound is exhaust. A tap tap sound is valve train. I doubt it is your valves. 86 has cross over pipe. Cat? Or cat delete? Either way lots of joints to leak. Not to mention the six ports that always seam to come loose
I'll take a video of the exhaust valve in question once I get in there and upload it.
Wouldn't a worn guide cause the valve seat to tap? |
Worn valve guides, broken valve springs sticking valves etc can certainly cause similar noise, however; I would first re-check the obvious i.e.; exhaust joints, ports etc.
Ant.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
I have same in my engine. It has not been rebuilt (I will do it next year).
A bit tap tap as warming up... when totally up to temp it is less. Valves are adjusted and even tighter than spec and it still makes the noise. I suspect it could be either - worn valves or guides - lateral movement of rockers on shafts (worn out bushings?) - the IMS gear having a bit of slop in it Hope to find out next year!
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
can you make a video of the sound? up and down on the left side of the engine??
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
