Car: 1978 Porsche Targa
Problem: Can't get new door hinge pins to go into hinges with new bushings. I searched some old files and one guy said that the pins are an extremely tight fit (no *****) and that the bushings need to be lightly machined. Is this true? Seems ridiculous to me that one new part (bushings) would have to be machined to fit another new part (pin). Well, my door is off and one new pin is hammered half way into the hinge and that's as far as it wants to go. Did I mention that the hinge is really hard to move now? HELLLLLP! |
1.367m later
He was right....pins and bushings need to be sized to work properly.
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
Kevin, thanks for the confirmation.
The bushing flange also needs to be sized to the other hinge half. Still amazed that these parts didn't come already machined to fit each other. Fine German engineering or rich mans' volkswagon, the jury is still out. |
Nice thread subject. You have to get an 8 mm reamer and ream the bushings to fit. You also have to fit the bushing flange. The did it that way so you would have a nice no slop door. If you have the tools and the knowhow it is no problem and you will be happy with the door
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Well Thom, if your going to bring logic into this then of course that makes sense.
I've owned old American cars for so long I forgot to stop thinking like a caveman. Jury says 'fine german engineering'. |
