Modified 911 - Oil Consumption
Hello Pelicans! Let’s talk oil consumption…at around 120K miles on my new to me 911 3.2L (circa 2015), I got concerned about oil consumption…nursed it for years and then pulled the trigger on a 3.4L rebuild (specs similar to dyno image below from Steve Wong’s website with more). The performance is great, but it consumes oil. My buddy said he could see black smoke out the exhaust. It is a highly tuned motor…essentially a de-tuned race motor (parts, etc.). What would be considered typical oil consumption on a modified motor like mine?
'88 911 Coupe (sunroof delete) / FRP/Carbon Front Fenders & Bumpers / Elephant Racing Suspension / 3.4L Motor Conversion |
What is the consumption you’re measuring? A quart per 1k? Less? More?
I have a very similar build (3.2SS, 10.2:1 Mahles, 993SS, chip, ported heads & TB, etc) and use very little oil, even with some very hard driving. Maybe 1qt every 3k miles or so, if even that.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ |
I had been seeing the needle on the oil gauge stop floating around 1,100 miles….give or take. It is more like 700-800 most recently.
It can take a while for everything to settle in, how many miles since the rebuild ? I too wouldn't be happy with 800 per quart. I installed the same P&C on my nephew's car and his consumption is negligible. Your buddy's comment about black smoke, is that on acceleration or cruise ? Black smoke is indicating a rich situation, oil consumption is blue smoke.
1986 Targa Guards Red 2021 MT09 SP |
Fill it to the mid point (don’t overfill) once warmed up + level, reset the trip meter and drive it like you normally would. Check again (level ground, warmed up) after 500mi or so.
Good point about the smoke…my friend who observed the smoke reminded me of the same thing. I remember the mechanic stating that when they revised the tune after the break-in, they modified the tune for mid-band performance. I was doing full throttle shifts…guess that might be the black smoke. T
Can I ask if you used synthetic for break in or a dino oil? If you didn't break in the motor with dino (regular oil no synthetic) You will need to dump all of it and you may have to change it a couple times to get everything to seat especially the rings before you put synthetic back in.
I would look at a good break in oil, Brad Penn, Driven, Amsoil, Lucas, Royal Purple, Contains high zddp, (zinc phosphorus) to help break in sealing of Piston rings, camshafts for performance engines. This should not be a long term oil, drained pretty quickly. I use brad penn or something similar, they are not Porsche motors though. When I drain it it is black and like water. I would at least call brad penn or talk to your engine builder about break in oil as the motor has 6k miles. Good luck I hope you find it. Kevin Last edited by Kevin Stewart; 10-26-2025 at 07:52 PM.. |
The way we broke in my engine was that we let it rip right out of the box essentially. Makes sure rings etc seat right away
Basically a race engine as well
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
Have you pulled the plugs to try and isolate the cylinder? Are you running valve seals?
The shop did a leak down test and said the results were reasonable.
Full Send Society
Not to derail, but in my experience anytime a shop does a test and only provides “acceptable” or “reasonable” instead of actual data, that test is highly suspect. Probably a good idea to do the test again and this time get actual numbers. It might not point to a smoking gun but real data>anecdotes.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
At the going price for an engine build these days I would fully expect print outs and hard data for things like this. The oil consumption would make me suspect blow by if the rings weren’t seated correctly, although (as others have said) black smoke isn’t typically oil. I’m also realizing the actual specs haven’t been posted: it’s like the screenshot, a detuned race motor… but what is it? A 3.4L with what P&Cs? Cams? What machine work was done, if any?
Piston & Cylinders - Mahle Motorsports 3.4L Conversion (PS98-010) 10:1 compression Carillo Rods Custom BBE headers and muffler ExtrudeHoned intake manifolds SW Chips rebuilt and bored throttle body 20/21 cams ARP rod bolts Competition titanium springs and retainers Custom chip for a 3.4 conversion programmed for 93 octane fuel
'88 911 Coupe (sunroof delete) / FRP/Carbon Front Fenders & Bumpers / Elephant Racing Suspension / 3.4L Motor Conversion Last edited by trentwat; 10-29-2025 at 06:00 PM.. |
Did you check all of the hoses going to the intake, airbox ect for oil residue? Had a diesel rabbit years ago that at 60mph it would blow oil into the air cleaner and blow smoke out of the tail pipe, oh and it was like having your foot on the floor lol.
If it's blowing black smoke, address that issue first, as excessively rich mixtures can allow fuel to wash the oil from the cylinder walls.
Although 1 qt in 800 miles seems a tad excessive by today's standards, it was actually within spec when the car was delivered. 1.5l per 1000km was the factory spec. |
T
Hi
If you rev it hard, it is going to burn oil..... Not a problem See typical Oil Consumption figures from Porsche below. Cheers Cheers
