What's a reasonable rim runout limit?
I just got a Starrett dial indicator and, since the rear of the 930 is on jack stands anyway, decided to try it out on my rear rims. I placed the gauge plunger out as far as i could on the rim near the tire
The RH rim varied from 0 to -.015 and then to +.005. So a total swing of .020. The LH side was better; it went from zero to -.012 and back. So total of .012. I intend to measure the fronts too, but I am interested in what the spec is. I understand that I am measuring total "installed runout" (my words) and that the observed runout might not be all rim related. What's the outside limit I should be looking for? When is it noticeable in a vibration or wobble?
Ken 1986 930 2016 R1200RS |
Ttt
if you need a dial indicator to see the runout than its not a problem
82 SC , 72 914 |
According to the Technical Specifications book 78-81 930:
Max permissable radial runout for steel rims 1.25mm Max permissable radial runout for alloy rims 1.0mm Max permissable lateral runout for steel rims 1.25mm Max permissable lateral runout for alloy rims 0.80mm Max permissable radial and lateral runout for rim + tire 1.50mm Great little books
-Wade 1972 Targa, nothing matching. Looking for motor 6124265 and transmission 7720299 |
Ed 1973.5 T |
Thanks for the specs and the link. Looking for that Tech Specs printing now.
Cheers. |
Hi guys, I just measured the lateral runout of my front right hub assembly after changing the bearing races and wheel bearings. 0.08 mm seems a bit much to me. What is your take? Unfortunately the car won’t be back on the road until spring since it is undergoing several projects..
https://youtube.com/shorts/aJUw84VLK6k?si=sB-Nvwf09SFC21me Car is a 1985 Carrera 3.2 |
PCA Member since 1988
That's about .003". Fuhgedaboudit.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
