140 psi oil pressure
Hi All, my 1975 911s runs at 140 psi when cold and generally always high. I have not confirmed this with any other gauge. Is this possible? could this contribute to an bad oil leak at the #8 nose bearing?
thanks in advance
Old 03-30-2012, 06:33 PM
Oh Haha's Avatar
At 140 psi you should have oil squirting out of every seam of the engine.
I would suggest checking the gauge wiring and verifying the true pressure with a different gauge.
Pacific Blue
Wayne
Old 03-30-2012, 07:53 PM
Send a message via Skype™ to Porboynz
If it is 120psi+ with another gauge then check for a stuck oil pressure relief valve.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 03-30-2012, 09:22 PM
baq911's Avatar
My oil cooler was recently tested up to 75psi with no leaks, is that enough pressure? Thanks
Old 03-31-2012, 07:50 AM
al lkosmal's Avatar
It is a distinct possibility that your oil pressure sender does not match your gauge. I would check this out 1st.
Check the top of the pressure sender for the part number.................should be 911-606-111-02 for a 75, i believe
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 03-31-2012, 09:22 AM
Thanks for the replies, I will purchase a basic accessory add on gauge and report back.
Old 03-31-2012, 11:47 AM
Only 13 years later, I got around to changing the oil pressure gauge sensor today. Wasn't that bad, about an hour or so. AC had been removed years ago
Now reading 60+ running psi
Old 11-11-2025, 03:25 PM
A930Rocket's Avatar
^^^ Ha! Better late than never to report back.
Old 11-11-2025, 05:50 PM
