Interest in 17Z/330mm (Cayenne) BBK for 911?
Hi all,
In the last few months I have started producing big-brake adapter kits to fit 2003-2010 Cayenne 6-piston Brembo calipers for the different models of 944.
Early 944s can use a 17Z caliper and 330mm rotors (for a 17" wheel) and late 944 and 951 can use 17Z/330 or 18Z/350mm combos.
The aircooled 911 front spindles/hubs are dimensionally similar to the early 944. They even share a front rotor (911 through '83) and the "hub height" is within 1mm. So I think it would not be a big stretch to modify these brackets to fit a 911.
If anyone might be interested let me know here or preferably by sending me a PM.
Attached are some photos including a comparison of a stock early 944/911 rotor vs the 330mm rotor that I modify to bolt to the hub. It is not a Cayenne rotor, but one from a Dodge Van (which means it is widely available and inexpensive, and drilled/slotted versions do exist).
Old 11-16-2025, 01:12 PM
