-   -   The best way to remove paint code tag without damage... (http://forums.pelicanparts.com/porsche-911-technical-forum/1186247-best-way-remove-paint-code-tag-without-damage.html)
AcidGypsy 11-16-2025 06:58 AM
Need some advice from those who know. I'd like to remove the tag before the car is stripped. I'm worried that a cut-off wheel might nick it.
Thanks.
http://forums.pelicanparts.com/uploa...1763305073.jpg
digdug 11-16-2025 07:28 AM
I cut a channel in each with a dremel and turned out the rivets with a screwdriver. If you look at the new rivets they have a twist pattern on them and kind of work as a screw. However once I got it off it was really corroded on the back so it went into the trash anyway. I had a fellow pelican stamp the new plate and it looks nearly identical.
CBA 11-16-2025 02:30 PM
You can buy a new one from Carbonne and have them stamps the exact paint code on it, if you want.
porschedude996 11-16-2025 02:38 PM
I think I drilled the drive screws out and used an easy-out. I bought a blank plate and stamped it myself. I changed the code from a gold metallic to black.
