DIY Rattle Can Inspo - Rear Bumper Corrosion Edition
When I got my 83SC last summer I noticed a little rust jacking at the top of the passenger side rear bumper strip. I really wasn't in the mood to dig into it, I just dropped a chunk and just wanted to enjoy the machine and take care of some other odds and ends, maintenance.
Now, I'm gearing up for some more involved maintenance items. The kind where not having a rear bumper makes things a little easier. So I figured I'd kill two birds with one stone.. 1, Practice removing rear bumper and 2, slowing/stopping corrosion
Maybe this might inspire some DIY bumper repair, since it seems to be a common theme.
Bumper off... I opted to remove at accordion. Thankfully all hardware was in good shape.
The worst of it...
Driver side, much better.. just a couple spots.
First pass at general clean up, see what im dealing with
By the way, does my muffler angle look pretty severe to you? Everything else lines up otherwise.
1983 911SC - Helibronze Metallic L966
Old 11-16-2025, 03:36 PM
Self Etch Primer and Upol filler as-needed
A few rounds of sanding, paint, cleaning and wet sanding later..
Mocked up with valance...
By no means perfect and fortunately covered up mostly by bumperettes and rubber strips. but im pleased and I can rest a bit easier knowing the damage will be severely limited if not halted altogether.
Shout out to Express Paint for the close Helibronze Metallic L966 match.
Old 11-16-2025, 03:37 PM
Still here
pmax's Avatar
That's a perfect match as far as I can tell.
Nice.
Old 11-16-2025, 04:00 PM
Hi
I think your rear bumper is made from an Aluminum Alloy.
If the correct primer is not used filiform corrosion, (clearly visible in your second photo), can occur between the aluminum and the primer.
Also etching of the aluminum with Alodine before priming can be helpful, in preventing corrosion and improving primer adhesion.
Hope this info helps.
Cheers
PS Apologies for any spelling issues !
Old 11-16-2025, 06:49 PM
Before and After in some better light
Old 11-18-2025, 02:59 PM
'82 SC TL
canamfan's Avatar
Well done Sir
76'S 1st Porsche white/can/can early rebuild (boo)
'84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1)
'87 Carrera cpe white/blue short flirt
'89 Anniv. sil/linen very pretty miss her
'88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Old 11-19-2025, 08:21 AM
