OsoMoore's Avatar
Gasket Set Came with Odd Ring - For Exhaust?
I'm reassembling my engine and instead of a final triangle gasket for the CAT-to-Muffler, I found this ring. It is shiny but not metallic, and looks like it would fit inside the joint from CAT to exhaust.
Is that what its for? Or should I track down a triangular gasket with the bolt holes? Is that triangular gasket a normal type I could get at the corner auto store?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 11-18-2025, 07:40 AM
you should have the flat metal triangular gasket 911-111-191-01 or 02
Old 11-18-2025, 08:09 AM
That type of sealing ring isn't unusual but to work properly you do need matching angled faces to allow it work. Do you have those inside your flanges?
Old 11-18-2025, 08:44 AM
OsoMoore's Avatar
I think so - I took a quick look and with the ring inside the gap was mostly closed (more than the ring's thickness). I'll do a closer look after work.
Old 11-18-2025, 09:45 AM
proporsche's Avatar
that ring is for 930 muffler clamp goes over it..All complete engine gasket sets come with this graphite ring.
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-18-2025, 09:58 AM
That kind of ring is also supplied with the crossover pipe that is sold in two parts as a replacement for the stock pipe with an accordion on the driver side.
Gilles
RoW 88 Carrera coupé
Old 11-19-2025, 01:44 AM
proporsche's Avatar
yup i forgot about this one thanx wazzz..;-)
Ivan
Old 11-19-2025, 03:47 AM
