Washer nozzle dilemma
I have run into a little problem on my 86 backdate.
The original washer nozzles were with heaters and no longer needed, plus they were destroyed somehow during disassembly. Searching for replacements without the heater wire , cannot find a nozzle that will fit the larger hole in the cowl. The earlier SC nozzles are smaller and do not cover the hole . Hoping to not have to spend for expensive originals that are not needed , hopefully someone has encountered that issue and solved it.. Any help would be appreciated ...
Old 11-30-2025, 03:26 PM
