Bright Red/Orange "Attention sensible to shocks!" Label in Engine Bay
Rooting around my engine bay (driver side firewall, near cruise control servo), I found the remnants of this label:
Curious, I tried a google reverse image lookup to see where exactly it may have been applied originally. No luck, the only examples I can find are the typical gold foil/black letter styles with "Danger High Voltage!" for ignition coil or CDI box.
It's a neat label, would be cool to know the story and possibly track one down to apply fresh.
1983 911SC - Helibronze Metallic L966
Old 11-22-2025, 01:33 PM
PCA Member since 1988
It came off either the ignition coil or the CDI box.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 11-22-2025, 06:55 PM
buster73's Avatar
Guess this sticker came off the cruise control actuator unit (91161712301).
Regards,
Guenter
73.5 911T, mod
Old 11-23-2025, 09:28 AM
Good guess. The same grammar error appears on both stickers in the French version of the warning.
Gilles
RoW 88 Carrera coupé
Old 11-23-2025, 10:44 AM
nice! great find, thank you
Old 11-23-2025, 02:49 PM
