-   -   Getting My Starter Back Wired (Hot-start Relay Edition) (http://forums.pelicanparts.com/porsche-911-technical-forum/1186559-getting-my-starter-back-wired-hot-start-relay-edition.html)
OsoMoore 11-24-2025 12:40 PM
Engine is almost ready to start up after rebuild, but scratching my head about the starter setup.
New wiring harness has 3 wires:
Big Red, Yellow 15a, Yellow 50
From the car body right nearby:
Big black
From my hotstart relay kit:
Blue connector (gets one of the yellows)
Small Black
Ground
My solenoid has:
Big bolt on left (ground?)
Spade on bottom (horizontal)
Spade on top (vertical)
I'm not sure exactly where they all go. Here's my best guess so far.
Yellow 50 -> Blue receiver
Yellow 15a-> Bottom spade
Small Black -> Top spade
All Three Grounds -> Big bolt
Something doesn't feel right about that - is the red from the engine wiring harness actually positive and should go elsewhere?
http://forums.pelicanparts.com/uploa...1764016659.jpg
Flat6pac 11-24-2025 01:03 PM
The big red coming off the alternator goes to the black wire, which is coming from the battery. They hook on a large terminal.
The solid wire yellow goes to the top tag yellow wire with the blue stripe goes to the bottom tag.
Bruce
OsoMoore 11-24-2025 02:55 PM
All good, thanks Bruce.
