Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Loose Fan Belt, symptoms?
all,
i was at the track this weekend and my car was really bucking and missing a little bit but only under full throttle. If i were to ease into the rpms without going full on foot down, the problem seemed to be less noticeable. i also noted that my alternator belt seemed a bit loose and i could hear some squeaking on startup but it went away. i was able to drive and have fun but not really being able to accelerate at full potential. in any event, the belt eventually destroyed itself and i noted that the car did not like it at all with a big miss and a little backfire as i was coming off track. i was able to drive the car at low rpms to get on the trailer and did not overheat as i caught it real quick.
can a loose or failing belt, that may be slipping really bad, cause the car to misfire or run poorly?
Thanks!!
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 11-24-2025, 07:05 AM
yes, if the battery voltage was very low due to the alternator not charging.
Ant.
Originally Posted by Kemo View Post
all,
Thanks!!
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 11-24-2025, 07:22 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
Once you get into it, make sure you have all six alternator pulley shims installed, either inside or outside the pulley halves. I have a friend destroy his fan's keyway by not installing the unused ones on the outside of the outer pulley half.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 11-28-2025, 04:01 PM
