Guardsred911's Avatar
Resurface pressure plate
I bought the regular Sachs clutch kit from the hosts - hasn’t completely arrived yet, but I’m seeing I had the hi performance lighter weight aluminum one previously installed. Can I get the mating surface resurfaced? I’d rather use this one as it’s higher perf than the one I purchased.
Presuming I should- if it’s even possible. I did get the flywheel resurfaced from the local shop.
J
911 SC - 1980
911 S - 1977
Old 12-08-2025, 06:27 PM
Rock. Auto has a whole sachs kit for less than what machining would cost
Instagram.com/timofthevalley
Old 12-08-2025, 09:25 PM
safe's Avatar
Nothing is impossible but it would be difficult to fixture it. Probably a lot cheaper to get a new one, its what you usually do.
Magnus
Old 12-09-2025, 12:14 AM
super helpful - thank you!
J
911 SC - 1980
911 S - 1977
Old 12-09-2025, 06:17 AM
Installed the clutch would polish the pressure plate.
Bruce
Old 12-09-2025, 09:00 AM
Happiest when Tinkering
gsmith660's Avatar
Been screwed by ******** too many times I wouldnt trust them to provide the proper parts and they have absolutely no customer service purchase from them at your own risk.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 12-09-2025, 10:15 AM
They sent me the correct parts
Old 12-09-2025, 01:09 PM
proporsche's Avatar
from the looks at your pres. plate it`s worn out,If you remove the TO bearing you`ll see the groove -it is gone, get new one..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 12-09-2025, 01:12 PM
gsmith660's Avatar
When was that recently? The first couple times I used them years ago they were great but in the last 2 years I got 3 orders and none were right first 2 they refunded me right away and paid shipping last order about a year ago they wouldnt refund until they got the part back and wouldnt pay shipping and all efforts to talk to customer service failed. Sure sign of a failing business.
Old 12-09-2025, 01:45 PM
The last dozen times ive used them over the last 5 years have been a pleasant experience
Old 12-09-2025, 03:12 PM
gsmith660's Avatar
Well I guess that’s good for you we are at different ends of the spectrum there are too many reputable parts dealers out to take a chance on these guys best of luck to you.
Old 12-09-2025, 04:04 PM
It's a 914 ...
stownsen914's Avatar
I've had mixed results having a pressure plate resurfaced. Years ago I had one done that worked out fine. More recently I had another one done and they damaged the housing (the aluminum part) of the pp. And the balance was way off afterward. I believe they disassemble the plate from the housing, so the shop needs to know what they are doing in order to do it correctly. After hearing stories of what happens when a pp fails, I decided against trying to fix it and got a new one.
Old 12-10-2025, 05:40 AM
