Front wheel hubs - bearings & cleaning
Car is: 83 SC (USA). As part of the brake refresh process, I removed the front hubs to get to the discs/rotors. Now that the hubs are out and on the bench, I want to change the inner/outer bearings, and the bearing seal.
As you can see from the fotos, the hubs are cake'd with grease and dust. So, would like to brush away the dust grease, soak in ZEPP Heavy Duty Citrus Cleaner (full strength), scrub, rinse, repeat. Goal is to get most/all of dust grease off --- not shooting for anywhere near full restored or concourse level. QUESTIONS: should clean it out first, then remove the bearings? Or remove bearings then clean? Does it matter? Is there any concern over getting the hub surfaces wet or will dust hide/deposit in those areas if I remove the bearings first? Thanks!
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil |
Pull the bearings first. Cleaning the hubs will be much easier. You’ll need to pry out the grease cap to reach the inner bearing. There’s a pick-like tool available, but I was able to work it out with a small pry bar. As long as you plan on installing new inner and outer bearings and a new inner grease cap, you’ll want all the old stuff out. Races, too, if you’re going all new. Those were the toughest part for me.
I like to use a combination of wire brushes to get it clean. Then for the extra magic step, get a scotch bright pad and soak it in penetration fluid. And scrub away. The oil in the fluid will help prevent staining of the bare aluminum. It will also repel water. And slow corrosion. WD40 can be used if you don’t have PB Blaster.
Remove the old. Clean and inspect. Replace with new.
Double check that the cleaner you mention is safe for aluminum, especially if you are going to let it soak. Common cleaners like Simple Green are not safe on aluminum. It's generally no big deal for a quick wipe, but it will damage parts left to soak. |
The 9 Store
I pull the bearings and seals, clean the hubs, then knock out the bearing races. I think it’s easier to knock them out when the hub is clean. No big deal ether way. Just don’t reuse the old races, install new ones.
All used parts sold as is. |
Thanks for your recommendations, everyone. Much appreciated. The front hubs are a mess, cake'd w oil/dust. I didn't think about penetrating fluid/oil. I do have PB Blaster and WD40. So, will try that.
Here's the plan: 1. use plastic scraper and thick nylon brush to remove as much crud as possible. 2. remove the grease seal/cap; remove inner/outer bearings 3. apply PB Blaster/WD40, scrape and brush more; wipe down, rinse, and repeat 4. rinse and scrub (or soak) w ZEPP, scrub, rinse, repeat 5. borrow/rent tools from FLAPS, and remove bearing race 6. wipe up inner areas where braces were seated; remove rust if any 7. install new races NOTE: ZEPP is labeled as safe for aluminum --- whether for scrubbing/rinsing or for soaking is not indicated.
Diesel fuel works real good to get the heavy caked on stuff. And for soaking parts.
Yeah, I've read/heard diesel, as well as gasoline, both work well to degrease.
I have a few gasoline storage cans, and some fresh 91 unleaded, so may give that a try. For diesel, I'd have to buy another container so will wait and see my results w ZEPP HD Citrus and/or 91 unleaded. I do have reservations about using gasoline/diesel though --- proper disposal is a real pain, here in California.
PCA Member since 1988
One shouldn't have to say this, but--don't use gasoline for the obvious reason that it's highly flammable. Use kerosene, diesel, or other less volatile solvents; or something nonflammable like the Zepp.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Ensure that you have this O ring part on your spindle. I'd suggest refreshing it based on the grit on your inner seal.
O-Ring for Front Wheel Spindle It helps keep the road grime out of the back side of your inner bearings. |
For sure --- working w the fumes and fire hazard always a consideration (to avoid working with it).
Front wheel bearing on spindle question |
I just did this. Mineral spirits and a parts washer work well to remove the loose stuff. I used an ultrasonic cleaner with aircraft cleaner simple green for the rest.
Brewster Green 1977 911S Outlaw Hot 2.7|10.5:1|Single Plug|Knightrace Cams|Weber IDA40's|SSI's|MSD Ignition Engine Built by Will Pyle Instagram: indy.alex.g |
Great to have another option to try, as I go down the list of the suggestions from everyone here.
@IndyAlex - Curious about your ultrasonic cleaner, what size/capacity? I searched on Harbor Freight. They had 2.5 L and 6 L versions. The 6 L version looked like it would fit the hub, or at least you could submerge it to a decent depth, then rotate it. How did it work with your set up? You used simple green --- so I guess the hub is steel, not aluminum? Read here that simple green on aluminum is not recommended. Thanks!
https://simplegreen.com/industrial/products/extreme-aircraft-precision-cleaner/ CTopher |
I bought this one, but it looks like it's no longer available. https://www.amazon.com/gp/product/B07G59ZYWJ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Quote:
I removed all Bearings and Races to install new, and then used a glass bead Blasting cabinet to clean the hubs. Be sure to heat the hubs before installing new bearing races that have been frozen over night. I applied a light clear coat to the hubs when finished.
1970 911T "Albert" 1986 944 Sold 1980 Euro 924 Sold 1967 911 Sold but Greatly Missed!! |
Very important distinction, indeed! I looked into this product label/specs --- does indicate it is safe for aluminum.
Perhaps I'm overthinking on this --- is the wheel hub/carrier even aluminum, or is it steel? Quote:
Thanks for the tips on heating the hub and freezing the races. I'll need to figure out the heating part --- where to do it.
Great results/fotos you got there. I'm afraid you've set a bar that is beyond what I've set for my SC, at least for this round of projects. My goal is to get all dust/grease off before, replace race/bearings, clean out the wheel well, reassemble everything, including brakes, and get it back on the road. Quote:
