Wiring diagrams for cockpit temp sensor
Hi,
Anyone know where I can find the wiring diagrams for the cockpit temp sensor, this is located between the sunvisors. I know it works with the heater flaps and the hose to the heat-exchanger (somehow). The car has the blower motor and the turning dial to set the desired temp, this is between the seats. Thanks -J This is where the temp sensor should be (I'll order it in the near future): http://forums.pelicanparts.com/uploa...0311_small.JPG This is where the controls are, check there is just 1 red lever, then a dial contol, then (further down) the green control to turn on/off the blower: http://forums.pelicanparts.com/uploa...0327_small.JPG |
That sensor is connected by two 0.5 mm wires, appear to be two different shades of gray, that run from the sensor location above the mirror to the printed circuit board in the heater control box between the seats.
Have you fished around inside where the cabin temp sensor was mounted? Those wires are probably still there. At the end of those wires, the plug that connects to the sensor is a right-angle connection that you will be able to grapple onto with a wire shaped just right. I don't know if the wires go to the left or to the right from that hole where the sensor mounts. Also connected to the printed circuit board are a black and a white wire that come from the sensor on the flapper box collar. |
| All times are GMT -8. The time now is 01:37 PM. |
