BARRY AT IAE - Recommendations
Does anyone have any experience with Barry at IAE in Detroit. Need to recurve the distributor and rejet Weber 40 IDA 3Cs.
Old 07-13-2003, 04:45 PM
Navin Johnson
TimT's Avatar
I believe he is the guy your looking for... The p/o of one of my cars mentioned a dist/ignition guru from detroit. He set up the ignition on the 914/6 i own.. It works well
'69 911 GT-5
'75 914 GT-3
and others
Old 07-13-2003, 06:24 PM
73911guy's Avatar
He is recommended by Bruce Anderson.
He recurved a distributor for me for my 73.5 911 which had been changed over to Webers. It solved every niggling problem I ever had with the carbed engine (spitting, popping, hesitation, etc). The engine had been worked on several times by two highly recommended mechanics and no one ever thought about the distributor curve being the issue.
If I had only learned of Barry sooner, It would have saved me years of frustration and many hundreds of dollars.
Jim
'73 911T
Old 07-13-2003, 08:19 PM
JCR JCR is offline
MDW,
Sounds like he knows his stuff. How 'bout sharing his contact info with your Weber carb-ed neighbor?
Jared
Met Silver '73 911S #0793
IrishGreen '69 912 #0602
Early S Registry #454
R Gruppe #391
Old 07-13-2003, 08:38 PM
Barry at IAE 313-532-5350
Old 07-14-2003, 06:41 AM
jmz jmz is online now
jmz's Avatar
Barry rebuilt and re-curved my SC distributor to work with the carbs and cams I selected for my rebuild. He also set me up with an MSD box and coil with a "plug and play" wiring harness. He was good to work with, helpful on the phone and stands by his work.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 07-14-2003, 07:53 AM
Halm's Avatar
Just did another archive seach and found that this might be your guy to do the recurve:
Barry at IAE 313-532-5350.
'17 Cayenne
Old 09-18-2003, 07:50 PM
