I have a later 915 Trans, Aluminum case, electric speedo. 8:31
r & p. Case #'s are 915/6? 74D3647 The number after the 6 was ground away. I suspect it is a 78 or later. Sceond question, please. The trans is missing the differential and axle flanges. I happen to have two differentials sitting around. The numbers are 911 332 212 0p On the second differential, the numbers are 930 ??? ??? ?? Did Porsche use 930 differentials on their later SC cases? Am I able to use either one of these differentials in the above case? Final question. What years 915 cases can I use for the axle flanges for the above case. Much appreciated! |
