-   -   Starting Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/118914-starting-problem.html)
Argeo 07-14-2003 06:51 AM
Starting Problem
The car is cursed I tell ya. I have straighten out everything important on the car but now I have a starting problem. In the morning when I go to start up, I turn the key and all I get is the solenoid clicking. No sign of the starter. I can leave and come back and it might start. If it does start, it starts fine the rest of the day. I have cleaned the battery posts and all the wires going to the starter. The soleniod is new so the posts there are clean. I am thinking that maybe the battery has a problem such a bad post. I had a kill switch on the battery that did put unnecessary, lateral force on the post. I removed the switch yesterday. Anyways, it was starting last night when I put away and wouldn't start this morning. It seems to be a reoccurring event. Another clue that may help is that sometimes there is a 1/2 second pause between when I turn the key and when the starter actually starts to turn. Any suggestions?
Rot 911 07-14-2003 06:59 AM
Did you check the ground cable from the tranny mount to the body?
Argeo 07-14-2003 07:02 AM
Hi, yes I did check. May be it came loose. I will check again.
Thanks.
Sunroof 07-14-2003 08:18 AM
The clicking solenoid saga. But, like you I had intermittent starting on varying conditions (hot-cold, etc). Sort of like a mind of its own.
I had the identical problem.....
I replaced the electrical portion of my ignition switch...no change.
I replaced the old starter with a rebuilt 1.5 hp unit....no change.
I replaced the tranny ground strap..............no change
I replaced the battery ground strap and added a new positive cable connector.....no change.
I installed a "hot start kit"..................no change.
I replaced the voltage regulator......no change.
I cleaned every connection til they glistened....no change.
FINALLY.....................
I replaced a fairly NEW BATTERY with another brand new battery..........BINGO, GLORY, SUN IS OUT, INCREDIBLE, DANCIN IN THE RAIN FEELIN GOOD, I LOVE PORSCHES AGAIN.................it was a bad battery!!!!!! Turned out one cell was not good.
When in doubt..............try that friggen battery first.
Regards
Bob
73.5T
Argeo 07-16-2003 06:31 AM
I think I found the problem as someone had mentioned. The car wouldn't start again last night so I ran a ground from the fan housing to the body and it started. The bolt that use to hold my ground cable on the body fell into the car. I put a bolt in it's place but it must not be holding too good. I am going to call and see about having a new one welded on.
Thanks for your help.
