-   -   Engine drop, not tranny, does shift coupler need disconnnect? Early 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/119010-engine-drop-not-tranny-does-shift-coupler-need-disconnnect-early-911-a.html)
H.G.P. 07-14-2003 06:50 PM
Two questions:
1. If dropping only the engine, does the shift coupler need disconnecting ? (1969 911 E)
Thanks.
(Read previous threads, but still concerned about oil line disconnecting also, would be nice to have a video VCR on a complete drop)
cowtown 07-14-2003 07:01 PM
In theory if you kept the transmission perfectly stable, you could leave the linkage attached. But I'd sure disconnect it to be safe. Big money if it bends.
Groesbeck Hurricane 07-14-2003 07:14 PM
I would do it no other way. We are talking about four screws to remove a plate and then another small screw to disconnect the linkage. You don't even have to crawl under the car. Simple, easy insurance against a big bill.
H.G.P. 07-14-2003 08:29 PM
OK. Does the hex screw come all the way out, and one then slides the rod out, or does the rod slide out automatically when this screw is just loosened?
Garrett 07-14-2003 09:02 PM
It's so easy to remove the whole thing at once (engine and tranny) you ought to just remove the whole thing as a unit and not risk forgetting to undo something.
cowtown 07-14-2003 09:29 PM
I'm assuming yours is similar to my '75, but here is what I do:
Put the trans. in first gear (or 2nd if you have a dogleg - you want the lever toward the front of the car) so the shaft is in the trans. as far as possible (makes clearance easier if you remove the trans).
Undo the 5mm hex bolt and remove it. It must be taken out completely, not just loosened.
Move the gear shift lever down toward the rear of the car to disengage the linkage from the trans.
Whole thing take two minutes, and one minute of that is looking for your hex key :)
H.G.P. 07-14-2003 09:46 PM
OK. Thanks. The selector rod, should it be marked, so it's original position can be restored upon installation?
And lastly, one naive question, where exactly will the rod end up after disconnecting the hex screw...out of the coupler and out the rear seat?
