Licensed User
Shuie's Avatar
Electrical restoration
I started pulling the front end of my 73T apart tonight and Ive got a rats nest of wires and in line fuses in my trunk now. Some of the stuff I can identify as aftermarket AC, Stereo, etc. One of the factory wire bundles going to the fuse block looks like a rat has chewed threw it. My turn signal circuits have been severed on both sides of the car by a PO.
Can I cut/pull this mess out and trash it? Is there a source for aftermarket or OEM source for spec wire bundles for the various circuits of these cars, or will I have to get the wiring diagrams and either splice the existing or fab my own wire bundles?
Any help is appreciated.
Old 07-14-2003, 05:58 PM
dtw dtw is offline
GAFB
I've got a bunch of harnesses (actually all of them I think) from a '71E Targa. Let me know if you need it.
Several BMWs
Old 07-14-2003, 05:59 PM
Cool
Hey Shu.. not for nothing, but my electrical design sucks..
The big picture is that I'll do a nice re-wire w/ tinned wire & circuit breakers.. and before I started re-working with the same stuff I'd probably figure that now is the time to do part of it.........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-14-2003, 10:50 PM
Licensed User
Shuie's Avatar
This place is great! dtw, I sent you a PM.
Old 07-15-2003, 03:55 AM
The severed turn signal wires are a sign the car has been repainted by someone who knows nothing about the 911.
The turn signal housings have a harness that plugs into the chassis harness at the body point mounting. No need to cut them, just unplug. Unknowledgeable painters just cut them.
If you search for new or used turn signal housings the harnesses should be complete and uncut. I kept an eye on ebay and finally got all 4, nice and new, at pretty decent prices. It took awhile but they are out there.
Good luck!!!
Fritz
1987 944S
1973 911E
Old 07-15-2003, 05:40 AM
304065's Avatar
www.ynzyesterdaysparts.com
$1600 for a new harness, concours perfect with German connectors.
Or you could fix the current one, time consuming but probably worth it.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-15-2003, 06:23 AM
