I’m looking for a set of dial calipers to measure, mainly, rotors and pads. I’m no engineer but I also don’t like wasting money on crap. Look at these two 6” calipers. Is it worth the extra $110 bucks? Am I missing something? What kind of calipers would you recommend?
http://www.sears.com/sr/product/summary/productsummary.jsp?BV_SessionID=@@@@0301593041.105 8454422@@@@&BV_EngineID=ccidadcilglgjhicehgcemgdffmdflh.0&vertical=SEARS&pid=00940165000&sid=I0057300010000100085 http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40926 Thanks R
Past: 04 Anniversary 911 #0895, 82 911 SC, 88 Signature Series Carrera, 88 911 Turbo Cab, 73 911T, 63 356B, 06 Cayenne |
For calipers/pads, etc... I'd go with the $20 calipers from HF.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
I didn't look at the sites, all I need to do is see the words Harbor Freight. Dreck. Made in China, almost all of it. I buy from them if I need something really cheap that I'll only use once or twice.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
I didn't look at the ad, either. However, here is my story.
I bought some $20 stainless steel 6" calipers from a local tool shop, Performance Tool, over a year ago. I brought them to work and the ISO guy put them up to his measuring blocks and they were actually more accurate over the range than my friend's $100+ Mitutoyo's. They still are in great shape and I use them probably every third day. IMHO, I think the $20 set works just great. |
Platinum Member
Consider a digital set. Push a button, measures in inch & metric, and converts. You should be able to find a decent digital for under $80.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Slumlord
To measure pads and rotors buy a $5.99 plastic one. They are suprisingly accurate. Won't rust and you don't have to keep it clean. Anything else, for your application, is overkill.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
on the same subject what would you use for more acurate readings such as cylinders, crankshafts and the like? Does a vernier caliper have enough accuracy?
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
I would not spend $130 on a Starrett caliper. The steel is too soft, and they will go out of calibration fairly quick. How about a nice digi-caliper? Most aren't much more $$ (if any) than the Starrett, but they are much easier to read, and are inch/metric switch-able. Do an internet search for: Brown & Sharpe, Fowler, & Mitutoyo "digital caliper".
I actually have an extra Brown & Sharpe (the "Porsche" of measurement tools) 6" digital caliper for sale if anyone's interested. Last edited by Eric Coffey; 07-17-2003 at 03:39 PM.. |
Slumlord
You need a good micrometer (or a set of micrometers) for OD measurements and a bore gage tool for ID's. A vernier is not good enough for most of those measurements.
I bought this from e-Bay. Best you can get with good price.
Caliber 1987 911 Cabriolet |
