panel's Avatar
CP/WURegulator adjustabilty(GOT PICS)
I read this article http://www.pelicanparts.com/techarticles/911_warmup_reg/911_warmup_reg.htm and wondered if anyone had a pic I could look at? Email it to me if you do or is it on the net?
2275T MS EFI '65 VW Panelvan http://www.vvwc.ca/minstone/
Old 07-17-2003, 03:06 PM
I did make my WUR adjustable. Here is a pic. It only changes the cold pressure though.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 07-17-2003, 06:10 PM
panel's Avatar
Thx Dean! Can you tell me if you ran the small hole 1.5mm down the side with a 1.5mm pin to help it from spinning or no?
Old 07-17-2003, 11:04 PM
No I didn't. Mine didn't spin. I just used the screw as leverage to pull the pin out
Dean
Old 07-18-2003, 05:30 AM
panel's Avatar
Do you know what your control pressure is at when the motor is up to temp?
Old 07-19-2003, 04:23 PM
Mine is lower than spec. I seem to remember 35 psi. But don't quote me
Dean
Old 07-19-2003, 04:38 PM
