one of gods prototypes
more 911 audio
well 993 actually but close enough LOL
these are from a customers car i did recently. custom enclosure bolted behind seats, holds 2 10's. amp rack this thing slams pretty freaking hard, will be no problem hearing at speed with the top down
Brought to you by Carl's Jr. Last edited by bell; 07-18-2003 at 05:29 PM.. |
are the two 10's behind speaker cloth?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Very nice!
Bell,
I'm putting together a system for my 911 and have a few ?? If I run Focal 165K's up front with a dual 8" sub setup in the rear footwells, how many amps do I need for good clean sound? What JL Audio amp(s) would you recommend in this application? Not trying to blow the indows out, just want good sound. I see you like the JL Audio amps. What's a good source? What are your thoughts on the new e series amps from JL? Thanks,
Eric Purdy |
the subs fire down, loading them like this keeps them from loosing control when the top is down......here's are a few more pics.
for the dual 8's i'd probably use the 300.2, we got in the new e-series jl amps in but i haven't played with any yet........i'm sure they'd work decent. head unit wise i've been using a blau toronto for about 6 years and won't change it until i absolutely have too, there is alot of good stuff on the market, stick with the name brands and something you like and that has more than 2volt output on the rca's.
Brought to you by Carl's Jr. |
Bell,
Is that a 300/2 just for the subs? I was thinking along the lines of a 300/4 with 2 channels bridged for the subs and the other 2 for the Focals.
Eric Purdy |
a 300/4 is a great amp and will do what you need it to, i would say that's a home run, i thought you only needed power for the subs.........it's early LOL
Thanks. I'm trying to put together a nice quality sounding system without breaking the bank:
Nakamichi CD-400 HU Focal 165K for doors Image Dynamics ID8 for sub encl. JL Audio 300/4 Thanks again
Eric Purdy |
