Dansk single in single out sport muffler Part Number?
Guys...any of you happen to know the part number for the Dansk single in single out aluminized sport muffler for an '87 carrera? :) Matthew
Here you go these are the 70 mm and 84 mm Tips and a
84 mmTwin tip part # 10 1010 157 Muffler Sport Aluminized Steel with Black Finish 70 mm Stainless Tail Pipe part # 10 1010 154 Muffler Sport Polished Stainless Steel 84 mm Tail Pipe Heres nice pipe this one, the tips are loose and you weld them on were you want part # 10 1010 156 Muffler Polished Stainless Steel 84 mm Dual Tail Pipes-Loose, to be welded at desired position. We have them here at Pelicanparts. Steve |
Thanks Steve. Any idea when the aluminized sport will be back in stock?
Matthew |
Dansk should also offer a loose tip version for the 84mm tip. They really don't quite fit right through to valence opening.
Dansks own number:
Single in single out 84mm: 92.502SL Loose tail pipe: 92.250S |
Matthew |
The number above is for a stainless steel "sports" muffler. I found it in a Dansk catalogue that I have. The non stainless steel OEM has a 60mm tail pipe. I think it's called 92.201 However it seems that it's also available in stainless, 92.201S
The aluminzed sport that I am looking for is out of stock at Pelican and every where else that I have checked. Looks like I will end up buying the S/S Sport! Appreciate your help. Matthew |
Matthew... just saw this thread today. The Dansk aluminized steel sport muffler (painted in crinkle black, with a polished stainless steel 70mm tailpipe) is a 92.501 (Dansk p/n). You're right, for some reason everyone has run out of stock on them. Pelican should be able to get you one after August 11. That's when stock should once again be available.
| All times are GMT -8. The time now is 02:34 PM. |
