Typical Fish's Avatar
Play in Steering Column...
My steering wheel/ column shakes up and down to the tune of about ¼ inch play in either direction. Is there a simple way to tighten this up?
TIA.
Matt
Old 07-16-2003, 11:00 AM
The plastic bushing in the steering column is gone. Pelican sells a metal sleave that just taps into place. Just remove the steering wheel.
Old 07-16-2003, 11:17 AM
scottb's Avatar
I've heard it's a VERY easy installation. Pull the wheel, tap the new bushing on. Replace the wheel. Voila! Apparently there's no need to remove the old bushing, and you can just push it down the steering column when you install the new one.
1984 Targa
Old 07-16-2003, 11:46 AM
Interesting.
Is this a pretty common problem, then?
Matt
Old 07-16-2003, 12:02 PM
Originally posted by Typical Fish
Interesting.
Very. Do a "search" you'll get several dozen explanations on how to replace the bushing.
Jerry M
'78 SC
Old 07-16-2003, 12:11 PM
Once you pull the center cover to expose the column nut and start to remove it, DON'T use the steering lock to hold the wheel while you loosen the nut. It can sheer or partially sheer the pin and cause you problems. Also mark a line on the position of the wheel to the steering column shaft so when you put the steering wheel back on it will still be lined up with the wheels. Other than that it's a piece of cake.
Dan O
84' 3.2 Targa
Old 07-16-2003, 01:06 PM
Ove Ove is offline
911 driver
Ove's Avatar
Talking
Typical Fish,
Worst part is getting the steering wheel (and the big 27mm nut that holds it) off.
I recommend that you leave the nut on by a few threads after loosening it. That way the steering wheel cannot hit you in the face when you pull it hard towards you.
http://www.pelicanparts.com/techarticles/911_Steering-bushing/911_steering_bushing.htm
Ove
'77 911S targa
Old 07-16-2003, 01:16 PM
CHILI's Avatar
I don't have any play in mine, but it knocks when I turn left to right or visa versa. While driving or sitting still. Is it a steering rack problem or can it be adjusted? That's one of the few things that I haven't tacked yet, so I have no idea about the workings of the 911 steering system.
By the way, Dan, why would it sheer the pin off if you use the locking mechanism? Seems like that's what it's for (to lock the wheel). Or is it just a piece of junk?
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 07-16-2003, 05:05 PM
The pressure you need to exert to loosen the nut may exceed the sheer pressure of the pin. The pin isn't meant for that type load, only to lock the wheel in position while the key isn't in and the ignition isn't opened.
Dan O
84' 3.2 Targa
Old 07-17-2003, 06:40 AM
Unregistered
sammyg2's Avatar
I had the same problem 6 weeks ago and installed the metal bushing from pelican, took me 5 minutes, piece of cake. I saved a great deal of time by using an air impact gun to get the nut off and my steering wheel was replaced last year so it came off easily with very little trouble. The bushing went in easily and tightened things up well.
Old 07-17-2003, 08:41 AM
I took a closer look at the play last night, and it in the whole column, not just the wheel. The column itself moves up and down all the to behind the dashboard.
Any thoughts?
Matt
Old 07-17-2003, 09:19 AM
I like to follow up with questions that I have asked on this bbs, so this is what it turned out to be:
The break-off bolts that hold the entire column assembly to the dash had stretched/loosened; I ended up taking out the tach (and rotating it and the speedo) and removing the existing bolts and replacing them with hardened hex heads. Mucho better; thanks everyone for the replies.
Matt
Old 07-21-2003, 11:27 AM
