jriera's Avatar
Send a message via AIM to jriera Send a message via Yahoo to jriera
Help please; Where this two cables go?
Putting back the engine.. but I have to cables that I cannot mate to anything and I cannot find the 'proper' picture on where they really go.. here are the cables:
They come from the main wiring loom.
Any ideas??
This is for a '73.5 (CIS) 911T
Thanks in advance.
Jordi Riera
'84 930 (modified)
Old 07-21-2003, 08:20 AM
Where are they coming out of in the loom? What components are the wire's exits from the loom near? My first thought is the one with a round lug is a ground and the other goes to the WUR. But I need more information. Jim
Old 07-21-2003, 08:54 AM
nick-moss's Avatar
The larger one may the earth on the engine lid.
Nick Moss - RGruppe #318
early911.co.uk
Old 07-21-2003, 08:55 AM
Mark Wilson
Guest
Posts: n/a
Is it soup yet?
Old 07-21-2003, 09:03 AM
jriera's Avatar
Jim, correction.. it does not come from the main wiring loom but rather from the 3 pin CIS loom.. so I guess that one goes to the distributor and the other to ground.
Any better ideas?
Jordi Riera
'84 930 (modified)
Old 07-21-2003, 09:04 AM
Probably then, the round eye lug grounds on a stud on the driver's side engine compartment wall forward of the CD box. The other wire may go on the distributor. I have a 73.5 engine with a new OEM wiring harness on a stand at home. I'll check the wiring this evening and let you know. Jim
Old 07-21-2003, 09:11 AM
Just looked at the online 7'3 wiring diagram and I suspect the black wire clips on a lug on the side of the distributor; there should be a black and blue wire mounted there too. The black and blue wire carries the tachometer signal forward to the instrument panel. Jim
Old 07-21-2003, 09:18 AM
jriera's Avatar
Thanks Jim.. I meant the CD box...
Found a good picture (in a different folder of course)
that shows both cables well..
Thanks again.
regards
Jordi Riera
'84 930 (modified)
Old 07-21-2003, 09:37 AM
Black wire clips onto lug on side of distibutor and wire with round eye lug is in grip of stud/nut which holds coil mounting bracket to fan shroud. Jim
Old 07-21-2003, 06:43 PM
