Hi,
While unfastening the targa top one of the handles came loose. After inspection, it has lost the small metal piece that crosses the shaft and allows the handle to engage the top mechanism (sorry but I can't explain it much better, here is a pic for clarification). Is buying a new one the only solution? Any ideas? |
Paco,
I've had luck sourcing used ones here: http://www.partsheaven.com/ New part pricing on these is ridiculous, IMHO.
Mark '88 Carrera GPW Sunroof Coupe '82 SC Targa (RIP) |
Paco,
You can also try Dan Pechtel at Cars, Inc (http://www.carsinc-nj.com/). He specializes in Targa tops and is great to work with.
I would think you could find something at a hardware store that would fit or coudl be cut to fit. There's some play in the handle when it's inserted so I think you could probably use some light solder to keep the new piece in position without impairing the function. I've got an extra one but after your experience I'm not excited about parting with it. But if all else fails, let me know. I would think the cheapest approach from where you are would be German ebay or used parts shops in Germany.
Dan Morissette '85 Guards Red Targa 911 My Owners Gallery Page Non illegitimi carborundum |
Who is John Galt?
Mine also fell out. I turned in a similar sized machine screw (#6 or 8 I think), cut the head off with a dremel, then ground down the sides of the screw until it slid into the slots. Note that one slot is bigger than the other because the original key was wedge-shaped. Has yet to fail.
'79 911sc Targa '02 slk230 kompressor '84 Tamiya Falcon A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years. |
You can probably drill a hole and insert the correct diameter roll pin.
Hey Guys,
I too had the same problem with mine when I first got it. After reading through the manual I found that the handle is meant to be taken off and put in the glove box when not in use. So needless to say it is not suppose to be in there tight. Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip One Way To Get More Horsepower Is To Get A Bigger Horse! "I couldn't find the sports car of my dreams, so I built it myself" Ferdinand Porsche |
Needle nose plyers have worked for me these last 10 years.
Dan Byers |
Thanks guys,
I will try to locate a correct sized pin, although I am very inexperienced at fabricating things. I am thinking about Rondinone's idea and it might work. Good excuse to buy a Dremel tool
Pelican Classified
I'm pretty sure I saw a used one for sale over in the classifieds
a few days ago.
Impotence...Nature's way of saying "No hard feelings." McDaniel 1974 911 Targa 1995 Toyota Avalon 2004 Toyota Tundra Extended Cab |
