Changing oil in 87 Carrara
Isnt there a technical artile page on changing oil on this site?? I cant find it. I have been changing my own oil for years but never on a 911. I was looking for a little guidance.
RockinRonF
Old 07-23-2003, 08:38 PM
buttjoint's Avatar
Use the search feature above and enter oil change and that should help you.
Old 07-23-2003, 08:43 PM
fogcity's Avatar
Bags and bags of kitty litter have something to do with it, I've heard
1984 Carrera Coupe
Old 07-23-2003, 09:31 PM
Sonic dB's Avatar
Its the same as any other car, except you have to drain the oil resevoir and the sum under the motor. Very easy... be careful not to overfill the engine...do 8-9 quarts at first and then add from there until the level is between the dots on the stick when the engine is warm and running on level gound. Got that?
Old 07-23-2003, 10:22 PM
Information Junky
island911's Avatar
And on draining; have a catch pan large enough to hold the volume . .. ~3gallons.
Old 07-23-2003, 11:06 PM
Blockchain Tech Inventor
jrdavid68's Avatar
http://www.101projects.com/
Buy our host's book.
A Mean Green Lifted 1972 C10
Long live the king!
Old 07-23-2003, 11:10 PM
nostatic's Avatar
remember that there are two drain plugs (or one and a sump cover depending on the year). You cannot imagine how quickly the oil comes out when you pull the oil tank plug. REALLY fast. Have a big catch pan that can handle fast flow/big volume.
Don't forget to replace the plugs before filling, and use new crush washers.
Old 07-23-2003, 11:51 PM
Even better, as I've posted before..is to use Fumoto forged brass drain valves ( teflon lined stainless steel balls....very nice piece). For both the tank ( 22mm) and sideways location on 3.2 engines ( 20 mm). Doesn't work well for the engine case sump vertical location of SC's because of ground clearance problems.
No crush washers....no dropped oil plugs in the pan...and a nice way to remove just a "smidge" of oil if overfilled.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-24-2003, 05:42 AM
Rick Lee's Avatar
You will make a big mess on your first oil change, no matter how much you prepare. Thereafter you can do it without spilling a drop. Nothing can prepare you for how fast it drains out and how much of it there is.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 07-24-2003, 06:09 AM
Wil,
Any suggestions on where to get the drain valves?
Tried a search here but get a CGI error.
Warren & Ron, may you rest in Peace.
Old 07-24-2003, 07:43 AM
Tips:
-use new crush washers every time
-use an awl to punch a small hole in the filter after oil is draining; this will release extra oil from filter and leave less to drip on removal. Also, after loosening filter, wrap plastic grocery bag around it and then remove it. Oil will then leak out of the filter into the bag, not on the engine.
Argo
88 Targa
Old 07-24-2003, 08:06 AM
Glasgow 911SC's Avatar
I believe it's actually REALLY REALLY REALLY fast!
Wear old clothes doing this!
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 07-24-2003, 08:10 AM
Send a message via ICQ to old_skul
And don't let the drain plug get into the drain hole of your catch pan. It does a fine job of plugging this hole. Get a pan with a screen.
Trust me on this one. :|
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 07-24-2003, 08:15 AM
Fumoto valves can be purchased from any number of places like the high-priced Automotion...don't know if our host sells them.
I have an old reference entitled "Fumoto Engr'g Co. of Americal" 425-869-7771 ( fax 425-869-2558). Haven't used it in some time so I don't know if it's current.
--Wil Ferch
Wil Ferch
Old 07-24-2003, 08:59 AM
Adman's Avatar
Send a message via AIM to Adman
If you choose to not use the Fumoto valve be certain not to use the large black oil catch pan with the built in funnel and spout. Even if you dont drop the drain plug and block the funnel inlet, the hole in the funnel section of the catch pan is to small to handle the volume of oil being released from the tank. A similiar catch pan comes in yellow and the top is wide open...no built in funnel and has a pour spout. This model works great!
Matthew
Old 07-24-2003, 09:20 AM
Mr9146's Avatar
Here's some real technical advice ...
Drain the tank first, then drain the sump. Do it when the motor is warm, not hot; that way it will drain faster and more completely.
Good luck and,yes, have kitty litter handy.
Old 07-24-2003, 09:44 AM
The Fumoto valve is good. I had one fitted on my oil tank after the threads became a little worn.
Chris
Old 07-24-2003, 10:44 AM
Senior Member
Jdub's Avatar
For the ideal drain pan set, go to your local thrift store or GoodWill and purchase a 12-pint stainless bowl and a smaller, 6-pint bowl as well. A restaurant supply house will have these as well.
I always clean my pans prior to dumping the oil, putting a small magnet at the bottom and letting them settle overnight then gently lifting and draining the topmost oil to reveal the "harder" stuff at the bottom. The magnet of course attracts the bad stuff for me to inspect.
Rubber gloves are a must. If you have not pulled your sump plate and inspected the screen etc. you should do this. I typically drop the sump plate every five changes to see how it is doing.
John
'78 Targa in Minerva Blue
Old 07-24-2003, 11:08 AM
