beepbeep's Avatar
SC shafts on -69 911?
We are selling our SC shafts (we are going to use Carrera shafts) and potential buyer want's to know if they fit his -69 911 w/ 901 gearbox?
Anybody who knows? As far as i remember, 901 flange has two pins and four bolt-holes, right?
Thank you for your time,
Old 07-23-2003, 09:56 AM
304065's Avatar
SC are 6 bolt. No fit 901.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-23-2003, 10:25 AM
beepbeep's Avatar
What about changing 901 flanges to SC flanges?
Old 07-23-2003, 11:48 AM
304065's Avatar
It's certainly possible. But if the only reason is to use the SC axles, I would advise against it. You have to change the stub axles in the banana arm, the axles themselves, and mill i think 1mm (check the archives, this is well documented) off the 915 output flanges to make them fit. If you were converting over to post-75 banana arms that already had the six bolt flanges, and you didn't want to change the wheel bearings (which would seem odd, considering you have a good chance to do it) that might make more sense.
'81 R65
Old 07-23-2003, 12:16 PM
beepbeep's Avatar
Thank you John!
Old 07-23-2003, 12:52 PM
