thrown_hammer's Avatar
Muffler is on, tips are straight... now about this heat pipe thingy?
I had to flatten the heat pipe in half to get the heat pipe back on. Is this allowing enough air across the heat exchangers? There are no restrictions or kinks. All the bends are still smooth. I used a press and a radiused plate to keep the radius on the back side of the pipe. So the passage in the yellow box looks like a "D".
What do you think? Am I okay? (seriously )
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 07-22-2003, 05:22 AM
Limbo
Slider79SC's Avatar
Shawn,
You should be ok. As long as you didn't kink the pipe then the shape ( D or oval ) should not affect the airflow. Look at Street rods and Nastycar racing, they use oval exhaust pipes for clearance so I would say you are good to go.
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 07-22-2003, 06:15 AM
The only thing I was worried about was that I reduced the volume of the pipe by half. I guess airflow should still be okay...
1975 911S (sold)
Old 07-22-2003, 06:27 AM
TerryBPP's Avatar
I hate to tell you but those tips aren't straight. Youv'e probably fixed them by now though.
Yes the pic is for reference only.
1975 911S (sold)
Old 07-22-2003, 06:35 AM
Limbo
Slider79SC's Avatar
I think that the only way to reduce the volume is to reduce the pipe i.e. a smaller diameter. As long as you have the same size pipe but just changed the shape, then the volume should stay the same.
Old 07-22-2003, 06:36 AM
But if I flattened the pipe on one side wouldn't it be half the volume of the original shape? It is completley flat on one half. Looks exactly like a "D".
1975 911S (sold)
Old 07-22-2003, 06:54 AM
Limbo
Slider79SC's Avatar
I think you should be ok, if you look at some of the high tech tubing parts and brake parts like this brake duct from SCarGo, they radicly change the shape but maintain the same amount of volume. I think that as long as you didn't cut out and remove any tubing material then you should be fine.
Shoot, its just the heat tube anyways. If there is a restriction in airflow its not going to hurt anything.
Old 07-22-2003, 07:07 AM
Okay my paranoia is recedeing. Alas my spelling needs a little work...
1975 911S (sold)
Old 07-22-2003, 07:17 AM
Limbo
Slider79SC's Avatar
Oh god, if I was held accountable for my spelling, life would be very ugly.......
Old 07-22-2003, 07:27 AM
Somewhere in the Midwest
MotoSook's Avatar
Shawn, if the cross sectional area has not been reduced by much, you should be OK. You can guess at that area, but judging from your description of the pipe shape, post-Hammer time, you should be OK.
And as slider said, why worry so much about the heat!
Old 07-22-2003, 07:31 AM
Souk,
I am mostly worried that enough air is flowing over the heat exchanger on the passenger side as to not cook my heads. It was stated in an earlier thread that I needed to have the heat pipe because it flowed air thru the heat exchangers displacing heat. I just want to be sure there is enough getting thru there to remove the built up heat.
1975 911S (sold)
Old 07-22-2003, 07:56 AM
Here is a couple pics of the muffler with the tips straight. (try not to notice the hammered heat pipe )
1975 911S (sold)
Old 07-24-2003, 05:32 AM
