-   -   Transmission input shaft seal on 915/3.2 question... (http://forums.pelicanparts.com/porsche-911-technical-forum/120403-transmission-input-shaft-seal-915-3-2-question.html)
ChrisL 07-24-2003 02:09 PM
For those that have replaced their transmission input shaft seal, is there both a seal and an o-ring? I see that Pelican has the seal (K-113-327-40) but I couldn't find a listing for the o-ring. I'm getting this from Bentley, which says theres both.
By the way, it's a 1986 Carrera.
Thanks,
Chris.
wevoid 07-24-2003 02:11 PM
Chris,
Yes - there is an O-ring, it is for the Throw Out Bearing guide tube. The input shaft seal is mounted inside the removeable guide tube.
Regards
Hayden
ChrisL 07-24-2003 02:53 PM
It's K-701-359-40. Just not with the transmission main seal.
Chris.
