Oracle's Avatar
Anyone know what's this?
Hi,
At first I thought it was the horn based on some German design but then I found the horns...
-J
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 07-26-2003, 10:47 PM
350HP930's Avatar
Heh, that is your very expensive A/C condenser fan assembly.
If its the original then its pretty likely that it no longer blows which will contribute to an underperforming A/C system.
Then again I imagine that you don't need it that bad in canada.
Old 07-26-2003, 10:57 PM
350HP930's Avatar
By the way, you should neutralize the acid and clean up the battery tray area before any damage occurs to your chassis in that area.
Old 07-26-2003, 10:58 PM
PRO Motorsports
Tyson Schmidt's Avatar
If it doesn't work, you can buy just the motor. You can drill out the rivets and separate the halves, the use a long allen to go through an access hole in one of the fanblades to loosen the set screw that holds on the fan. From there it's self explanetary.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 07-26-2003, 11:14 PM
Oracle's Avatar
Thanks for the remider, I'll use the baking soda+water approach, to clean the area before it's a problem, right now it on the surface only.
About the A/C condenser thanks, now I know what is that... And it should work OK because the A/C works like a charm in the 2 week warm weather here in Canada
Bye
-J
-Oscar Wilde
Old 07-27-2003, 08:41 AM
Send a message via AIM to Supergranule
on my 71 a prevous owner hooked that a/c fan thing to a front mount oil cooler. i've never seen a set up like it before...has anyone seen something like that?
Old 07-27-2003, 11:04 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
I believe that is the stock set-up on the SC. At least, that is how my SC is set up.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 07-27-2003, 11:24 AM
