72 four door's Avatar
interchanging seats
Hi i have a pair of 80 sport seats froma 911 without mounting brackets Will my 72 stock seat brackets bolt up to the 80 sport seats?
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 07-28-2003, 07:16 AM
Anybody?
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 07-28-2003, 10:00 AM
The short answer is that you need an adapter to bolt the '80 seats into your '72. I've seen them advertised, maybe Pelican carries them.
The bigger problem is how to mount seatbelts. Your '72 has the belts mounted directly to the seats, where the sliders attach. The '80 had mounts in the floor. So, if you install the '80 seats in your car, then you will have to cobble something together to mount the seat belts. I have not seen a satisfactory adaptation of the seat belt mounting arrangement. Maybe someone on this board has a bright idea.
Old 07-28-2003, 10:39 AM
Double Trouble
targa911S's Avatar
You can make the adapters yourself with stuff from Home Depot. 2"X1/8 mild steel flat stock. You will have to weld "ears" on the outside of the rails to mount you seat belts. Or you can buy all you need from our host or petco.com. Rails are $110.00 ea seat, and seat belt conversions are $150.00 per seat.
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 07-28-2003, 10:55 AM
Thank you very much
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 07-28-2003, 10:58 AM
