H.G.P.'s Avatar
What is the torque (ft/lbs) setting for pressure plate bolts?
When installing pressure plate bolts(clutch job), what torque value in ft/lbs, do I set my torque wrench to? (69 911)
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 07-27-2003, 02:56 PM
25 ft-lbs (according to Haynes manual)
Chris.
'95 993 C2
'86 911 (sold)
Old 07-27-2003, 03:01 PM
Early_S_Man's Avatar
Porsche Crest
Aren't the bolts standard DIN 8.8 M8 bolts???
If so, then Haynes is wrong or somebody transposed Lb-Ft and Nm ... because the proper M8 torque is 18 Lb-Ft, or 25 Nm!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-27-2003, 05:29 PM
I double-checked the Haynes manual, and it does say 25 ft-lbs. The later Bentley Carrera manual says 18 ft-lbs, so Warren is likely correct, and the Haynes number is a misprint.
Chris.
'95 993 C2
'86 911 (sold)
Old 07-28-2003, 03:15 AM
