Distributor woes
I've just replaced my right-hand side intake manifold and fitted all back together. Well almost all.
When I came to fit the spark plug wires back to the distributor I got stuck! I can't find the drawing I made to remind me which goes where ... This is on a 1969 911S ... the firing order is 1-6-2-4-3-5 according to my Haynes manual... Can anyone have a look at their distributor and let me know please ? Thank you very much in advance...
'69 912 with tired '68 911S 2.0 smoker Last edited by AME; 07-29-2003 at 06:42 AM.. |
Number 1 should be marked on the distributor base. I don't remember whether you distributor rotates clockwise or counter clockwise but once someone chimes in and tells you just follow the firing order from there.
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
I found this post:
(start quote) Um, the wiring order is the same as the firing order, 162435. Is that your question? Put the motor at TDC on #1 (there should be a little mark on the distributor about where the rotor is pointing. This is where the #1 wire goes. Then just put on 6,2,4,3,5. (end quote) Could be that it was too dark - but I couldn't see a mark on the distributor cap. Can I assume that spark plug cable #1 belongs on the whole that is the one immediately to the left of the fastening clamp? (on the 'front' of the distributor so to say - ie towards the rear-end of the car) ?
'69 912 with tired '68 911S 2.0 smoker |
Friend of Warren
AME the mark is a small notch about the width of a pencil led on the top edge of the distributor housing, not the cap. It is in about the 4 or 5 o'clock position.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Aah! I never thought to look there. I only look on the cap.
Thanks and hopefully I'll get it sorted. Ideally there'd be a drawing of left and right cylinder banks showing which cables go where - made especially for newbies such as myself
