Rear License Panel
Is there an easy way to remove the Rear License Panel (1970 911)? I removed the bumper guards and found two more bolts at the bottom (on each side) to remove. I couldn't get a wrench in there and when I tried a socket, I could turn it because the wrench kept hitting the muffler and I couldn't even get a click out of the socket. Tell me there's a trick?
Signed,
Bradley
aka
Big Doofis
1970 911E Sportomatic Sunroof Coupe (with an 8-track player)
Old 08-01-2003, 09:12 PM
pwd72s's Avatar
uh...maybe pull the muffler?
Old 08-01-2003, 10:01 PM
Stressed Member
Scott Clarke's Avatar
I got at mine with an open end wrench. The fasteners you are refering to are sheet metal bolts, so they are easy to turn once loose. Perhaps yours are rusted. Good luck, and keep trying!
-Scott
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 08-01-2003, 10:06 PM
Warren Hall Student
Bobboloo's Avatar
You might try loosening the left and right bumpers a little bit to give you a little room to work with.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 08-02-2003, 01:06 AM
You do not have permissi
john70t's Avatar
Try 1/4 in drives with wobbly extensions, also you might want to replace them with allens for ease.
Old 08-02-2003, 10:07 AM
