911sc - elec. window stuck half-closed
Car has been stored for a few months, and we'd left the driver's window open to let air circulate in/out of the car while sitting in the garage.
Came to move the car, reconnected the battery - BUT the driver's window went up, almost closed fully . . then stopped, and won't go up or down! THeres a 1/2" gap left. Is there a way of manually winding up an electric window - as a stop gap measure while I try to find the source the problem. Presume as a starting point take off door interior trim, lubricate window mechanism, any special way to do this? and swap switch over from passenger side as that works? Any other tips? Thanks:) |
Have you checked the fuses?
This happened to me last week, replaced the blown out fuse and now works ok. |
Is the opposite window working , it's usually fuses or the relay I've found with these windows , although many here have had dodgy switches too .
Can you hear the motor at all? Mine has done the same before, but I could hear that the motor was straining. problem was one of the nylon wheels had jumped its track, knocked it back in and lubed and all was well.
| All times are GMT -8. The time now is 10:41 AM. |
