vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Wheel Spacers on an SC?
I have a mostly stock SC Cab and was pretty sure I could live with the stock wheels and spacing - but after reading some recent posts I can't look at the car w/o noticing the extra space in the rear wheel wells? How doees the spacing affect alignment and ride height and what spacers do you recommend? Are front spacers recommended as well?
Still not convinced I need/want them?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 07-29-2003, 04:33 AM
I used 1" spacers on the rear of my SC w/ 7" Fuchs. Really filled the wheel well out nicely. I purchased them from a board member. Be sure to get the type that center the wheel not just a flat spacer. I used a 1/4" flat spacer on the front (the type that does not have bolt onto the hub) and had some vibration due to the wheel not being centered on the hub. There is a source in Excellent in Puente Hills, CA (I think) that provide an excellent product. I beleive the name is Booth if I am not mistaken.
Old 07-29-2003, 08:50 AM
Caution:
Be careful. Spacers come in two flavors..those that are bolted to your original hub and have 5 off-set studs that are of the proper length ( you then end up with ten "lug nuts" ,...if you will,.... per wheel)
-OR_
The spacers that simply slip fit over the normal studs. In this case, you should use longer studs to make up the length-lost by adding the spacer in the first place.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-29-2003, 10:06 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
It'd be alot easier to run a fatter tire.
Marc
Old 07-29-2003, 10:41 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Are there already spacers on 911sc hubs, cause i think i noticed that the last time i looked at the hubs? I'm used to the 944 where there's nothing but the brake rotor behind the wheel so i find it odd that the factory would use spacers.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 07-29-2003, 11:58 AM
There shouldn't be.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 07-29-2003, 12:00 PM
1fastredsc's Avatar
Then i guess the PO installed spacers on my sc previously.
2007 Mazda 3 hatch
Old 07-29-2003, 12:03 PM
Senior Member
Superman's Avatar
Yep, the PO must have installed them. One inch would have been too much in my case. I am using, I think, 23mm spacers. I installed the longer studs for this. I like the look much better, but the real way to fix this is with 9" wheels.
Mocha 1978 911SC. "Coco"
Old 07-29-2003, 12:11 PM
