Question Electrical Crisis
Okay, so I just dropped the motor in my '83 SC to replace some leaky oil seals...
A few days after having it back and running, my tachometer started jumping around at very random and occasional times while driving. At times it would die, like its ground was losing a connection. Then, the battery charge idiot light came on. This would happen for a few seconds, then everything would bounce back to normal.
This morning, the battery was dead.
I checked the battery terminals, which were clean and tight. I disconnected/reconnected the battery with no changes.
I'm thinking of a few possibilities... 1) The alternator was dieing. 2) The regulator died. 3) I have a bad ground strap--maybe the transmission to chassis? or 4) the battery was dieing, not taking a charge, and finally crapped out.
Help!
Old 07-31-2003, 07:33 AM
Heck, I’m only 5 not 71!
targa80's Avatar
A bouncing tachometer is indicative of a charginging system problem. Do a search on bouncing tach there have bee several good threads on troubleshooting this problem.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 07-31-2003, 07:45 AM
McDaniel's Avatar
Bouncing Tach
9 times out of 10 a bouncing tach is caused either by a bad ground or a bad vr (as you indicated you suspected) I'd check
those first.
Impotence...Nature's way of saying "No hard feelings."
McDaniel
1974 911 Targa
1995 Toyota Avalon
2004 Toyota Tundra Extended Cab
Old 07-31-2003, 09:28 AM
also..
the dizzy sends a pulse to the CD box.. the CD has a circuit that shapes the pulse to a signal for the tach
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-31-2003, 10:15 AM
