LeRoux Strydom's Avatar
Headlights flashing
I just noticed recently that my car's headlights (high beams) do not flash if I pull the stalk on the steering column with the lights switch off and ignition on. Is this the way it's supposed to be? Pulling the lights switch out into parks or headlights on position, and the high beams flash when I pull the stalk.
My drivers handbook make no mention of being able to flash the high beams with the lights off. Car is '78 SC RoW spec.
How do everyone else flash other Porsche drivers?
thanks
LeRoux
'90 964 C2 coupe (sold )
There are no old Porsches, only new owners.
Old 05-05-2003, 02:44 AM
Buy them, sell them
Adam's Avatar
Yep. You're doing it right, so you might have a slight electrical gremlin.
Do the headlights work on high-beam when they're switched on?
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 05-05-2003, 02:58 AM
Yes, everything else works the way it should, i.e. pull the headlight switch on the dashboard, and I get low beams with the stalk pulled up and high beams with the stalk pushed back. Pulling the stalk further forward from the low beams position will flash the high beams while being held there. So it seems as if the steering column stalk switch works fine. Only problem is, no flashing when the lights are switched off! Is this peculiar to my model year car, or is something wrong?
thanks
LeRoux
Old 05-05-2003, 03:11 AM
911 + 129 = JOB
PDACPA's Avatar
I thought this was about passing the fellow P car on the road and giving a headlight blink!
1989 911 Carrera Coupe 3.2
2012 BMW 135i M Sport
"It is not how much power you have, it is how much you have left to spare!"
Old 05-05-2003, 07:16 AM
This is exactly what I'm trying to achieve !
LeRoux
Old 05-05-2003, 08:14 AM
I have an 80 SC and they flash in the headlight off position with the key off too. Pull back towards the wheel.
Cheers
Old 05-05-2003, 09:06 AM
Cheers
me to
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-05-2003, 09:12 AM
steve911's Avatar
LeRoux--
I had a similar problem with my '85 Targa. I took the switch out and re-aligned all the connections. There are (if memory serves) 3 metal tabs. Align them and CLEAN the electrical contact surfaces and it should start working again.
edit: to clarify as per Jamie's (correct) observation
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 05-05-2003, 10:08 AM
I would rather be driving
jpnovak's Avatar
Not only alignment but clean the contacts. You can do both with the swtich in the column after taking off the shroud. Yes, you must pull the steering wheel to get the shroud off.
Jamie
Old 05-05-2003, 10:57 AM
problem fixed!
So this weekend I had some time to mess around with the electrics on my car. After studying thediagram below from my trusty Bentley, and scratching my head a little, I found that the red/white wire indicated in the diagram was swopped for another white/red wire on the lights switch, which prevented current flow to the pull stalk switch when the lights are turned off. Pretty subtle, but then easy to confuse if you're in a hurry. The red/white wire is a red wire with a white stripe, vice versa on the white/red.
After swapping them around, I can now flash with the best of them! Yeah, pretty trivial fix, but it gives me closure........
LeRoux
Old 07-31-2003, 10:50 AM
