HELP!!!!! Engine sounds wacky!
Had the car parked in the street and golfball-sized hail started to come down. I ran out, started up the car punched the gas and pulled ahead a few feet, and then punched the gas and backed up so I could get the car in the driveway, and then punched to actually get in the driveway under cover of the trees. Now, at idle the engine kind of sounds like a diesel!!!!!!! Like there is just way too much stuff happening in there that wasn't happening before.
F()CK!!!!!
Any ideas of what I might have done?
1987 Carrera, Guards Red, Black (sold but never forgotten!)
1965 356SC Coupe, Silver on Red
Old 07-30-2003, 06:37 PM
Super Moderator
cstreit's Avatar
Detonation or pre-ignition might cause this...
Did you change fuel lately, get water in the fuel, etc?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-31-2003, 04:34 AM
TSNAPCRACKLEPOP's Avatar
sounds like all hail has broken loose!~!!!lol
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 07-31-2003, 06:16 AM
Senior Member
Jdub's Avatar
Any sugar around the gas cap? Any petty vandalism you notice?
Hard to believe that simply starting and moving the car back and forth in an aggressive manner would cause a problem.
John
'78 Targa in Minerva Blue
Old 07-31-2003, 07:19 AM
Fuel has been fine...untampered with. I'm going to run it over to a Porsche garage and have them give it a listen. I actually stayed up late searching for clues as to whether or not I might have bent a rod, valve, etc. Driving me crazy.
Old 07-31-2003, 08:18 AM
When was your last valve adjustment?
88 911 (Sold)
87 951 (Sold)
Old 07-31-2003, 08:20 AM
adamred's Avatar
My car's at ******** in Chatham right now going in 15 minutes to pick her up, Gene's the kind of guy who will take some time, give it a listen/advice and then pull it into the bay for real work time if necessary....
Adam
Adam,
2019 BMW 540i
Old 07-31-2003, 08:30 AM
