-   -   Quiz for master mechanics (http://forums.pelicanparts.com/porsche-911-technical-forum/121433-quiz-master-mechanics.html)
Burnin' oil 07-31-2003 01:52 PM
I replaced the points on my '73 911 yesterday. After replacing the rotor and the cap, I attempted to start the motor. As soon as I started cranking I heard an awful racket from the motor. It sounded like someone violently shaking a steel bucket of parts. I stopped cranking, scratched my head and tried to figure out how such a noise could be created merely by changing the points.
I read Wayne's project book and the Haynes manual but could not figure out what I had done wrong. I then inspected the motor and soon realized what the problem was. Anybody want to take a guess?
Formerly Steve Wilkinson 07-31-2003 01:56 PM
You put the cap on 180 degrees out of phase, if that's even possible?
Stephan
Burnin' oil 07-31-2003 01:59 PM
No, that wasn't it. I thought about that but assumed that reversing the cap would mean that the car would not run but that it would not cause any noise.
Early_S_Man 07-31-2003 02:11 PM
Did you remove the distributor to install the new points? If so, you may have put it back in 'off' one tooth on the drive gear ... it would start, but run like a bucking bronco on a couple of cylinders!
Burnin' oil 07-31-2003 02:12 PM
Warren:
I did not remove the distributor. Try again.
Wayne 962 07-31-2003 02:15 PM
I would guess that you placed the plug wires in a counter-clockwise orientation, like on the 911SC, when it should be clockwise for your car. This is a very common error, and one that I have made once or twice myself...
-Wayne
Burnin' oil 07-31-2003 02:16 PM
You guys are thinking too hard. Think more along the lines of bonehead.
Stu Wilkinson 07-31-2003 02:16 PM
Were you turning the motor over using the nut on the fan to find TDC, and left the socket or spanner on the nut when you started the car?
CHILI 07-31-2003 02:17 PM
You forgot to push the rotor all the way on the shaft and it few off and was being beaten around inside the Cap?
BTW, I forgot to put the rotor back on once. Counldn't figure out why it wouldn't start! What an idiot :(
Burnin' oil 07-31-2003 02:17 PM
Way to go Stu. You sound like a man that feels my pain.
Wayne 962 07-31-2003 02:18 PM
Left your screwdriver leaning against the blades of the fan? Forgot to tighten the points plate? Dropped something into the area where the fan meets the pulley?
All big bonehead things there...
-Wayne
Wayne 962 07-31-2003 02:19 PM
A very dangerous situation!
-Wayne
Burnin' oil 07-31-2003 02:20 PM
Stu got it. I left a 1/2 inch drive ratchet on the fan bolt. Its a wonder I can make it through a day . . .
Stu Wilkinson 07-31-2003 02:23 PM
Woohoo!
Winning the quiz for 'silly mistake of the day'
I have not done that one, but nearly have several times.
Hope no damage was done.
Zeke 07-31-2003 03:45 PM
While working on the motor, I saw a plastic cap for a paint spray can or carb cleaner laying in there. That would have been nice in the fan. A thorough once over at the finish of each job needs to be routine. I haven't left too many tools in the engine compartment over the years, but a few. About half of them I never saw again.
Wayne 962 07-31-2003 05:26 PM
The 356 has a huge rear engine shelf. I've opened up my engine compartment (in the past) to find tools that I had been missing for months!
-Wayne
slakjaw 07-31-2003 05:52 PM
Dropped a wrench in the super charger?
