Distributor Advance problem
Help guys... (89 turbo)
When the vacuum hose is connected to advance of the distributor the car hesitates and misfires badly under load. The CD and coil check ok and the hall effect has been replaced. Timing is correct. Currently, i can only drive the car with the vacuum hose disconnected. Considering this I would replace the entire unit with electromotive HPX or TEC3 if i knew i could get it by the smog police (here in california). Any ideas? Thanks, |
vacuum advance unit on disti may be bad. fixed my problem.
| All times are GMT -8. The time now is 05:59 AM. |
