-   -   911 engine codes (http://forums.pelicanparts.com/porsche-911-technical-forum/121529-911-engine-codes.html)
Larmo63 07-04-2020 12:42 PM
My car supposedly has it's original motor *6383769*. 930/03
'78 SC 911831163_
paulitr6 07-04-2020 02:16 PM
Thank you, So I would guess the it is original to the car. i have no option stickers or manuals so no way to know for sure .
Thanks Again
74Sahara 09-24-2020 04:58 PM
Another Numbers Matching Question from a Newb
Hi guys, I recently purchased my first air cooled Porsche, a beautiful 1974 911 base. Trying to figure out if it is the original motor and based on my research I am fairly certain it is. Looking for some other opinions... So the car is a 2.7 G obviously, first year for the 2.7 and based on the vin, the manufacture date of the car is December of 1973. The engine code is 6134792 which is the slightly confusing thing. My understanding is '74 was the first year for the 2.7 correct and since it was built in 12/73 does that make since with the 3 in the code? Does it make sense that this would be the original motor? Thanks for the help!http://forums.pelicanparts.com/uploa...1600991850.jpg
VIN is 9114101937
JJ 911SC 09-24-2020 05:05 PM
Post a pic of the VIN.
74Sahara 09-24-2020 05:16 PM
VIN is 9114101937
JJ 911SC 09-24-2020 05:46 PM
1974 911 (base) 9114100001 - 9114104014, 4014 Produced
Matching Engine Serial # = 6140001-6146625 Type 911/92
So your engine # 6134792 seem to belong to a1973 911T US, CIS; Type 911/91 .
Things being equal (4014/12= 334.5 a month), thus 9114101937 would be around Jan 1974
Can you post a pic of the Engine Type 911/xx.
74Sahara 09-24-2020 06:35 PM
Thanks JJ, appreciate the information. I need to get some additional pics of the engine and post them up. The car is currently in the shop getting some work done, but this is super helpful.
Actually I realized I had a typo, it should have been 9114101957, not sure if that makes any difference...
74Sahara 09-24-2020 06:41 PM
http://forums.pelicanparts.com/uploa...1600998058.jpg
djpateman 09-25-2020 07:42 AM
The VIN is coded for 1974, the engine is coded for 1973, therefore definitely not the original. In the last 45 years, anything could have happened to that engine. Perhaps the case was damaged, and they found the 73 case and used it to rebuild the engine. Or, that engine could still be the an original 2.4.
The original Maintenance record book might have the original engine #. The only other way to find the engine # that I know of is to use a service like mine to get a CoA type report that has the information. The current PCNA offering, the PPS, requires you to provide the numbers for verification, but I do not.
MadeofOak 11-12-2020 02:26 PM
A few people have asked about my engine, I'd like to pass on info.
911/91
6134061
http://forums.pelicanparts.com/uploa...1605219810.jpg
Thanks! :)
MadeofOak 11-14-2020 07:41 PM
Anyone with the info? :)
djpateman 11-15-2020 10:35 AM
911/91
6134061
911T CIS for North America
2341cc (2.4)
140HP @5700rpm 201ft-lb@4000rpm
Tom Oxner 11-19-2020 11:12 AM
I have engine type 901/14, with engine number 3280982. It was owned by the late Grady Clay. If anyone is looking for this engine to match their car, let me know. Thanks,
Tom
djpateman 11-19-2020 01:51 PM
Tom, I don't know what car that belongs to, but I will add to my database. Can you find the build number next to the type # please; 13629 or higher.
Dave
Tom Oxner 11-19-2020 06:03 PM
Hello Dave:
The build number for 901/14 #3280982 is 13629. Thanks for putting this in the database.
Tom
JSV798 11-20-2020 04:13 AM
Anyone come across Porsche 911 engine codes by Dr. Culata? Stumbled over this today and seems to confirm that my car was originally a sportomatic. Engine number is 6389217 and the 9 seems to indicate that it was a sportomatic (code SPM ) on page 15 of this compilation. As most of you will know the 6 is for 6 cylinder; the 3 is engine type; the 8 is year -1978-; and it seems that serial nos.
0001 to 9000 are for manual gearboxes and 9001 onwards indicate sportomatics.
Thought this might be of interest.
djpateman 11-20-2020 04:18 PM
You are correct for that engine #.
carycole 03-15-2021 11:08 AM
Carerra 3.0 new engine casing
I am looking to buy a 1977 Carerra 3.0. Owner says the engine casing was replaced when the engine was rebuilt. Will it have a new engine number? Does this automatically make it a non numbers matching car? Thank you!
onboost 03-15-2021 11:59 AM
If the case was replace, and purchased from Porsche, it will be blank, unless someone re-stamped it.. and that's somewhat of a grey area.
I would say its non-matching, because how would you match the car to the engine.. with no number?
Is this a US CIS or Euro MFI 3.0 Carrera?
carycole 03-18-2021 10:36 AM
I believe it is a MFI. I do know that it was imported from Germany in the 1980's. Wouldn't that make it a MFI?
