Rear License Panel
Is there an easy way to remove the Rear License Panel (1970 911)? I removed the bumper guards and found two more bolts at the bottom (on each side) to remove. I couldn't get a wrench in there and when I tried a socket, I could turn it because the wrench kept hitting the muffler and I couldn't even get a click out of the socket. Tell me there's a trick?
Signed, Bradley aka Big Doofis
1970 911E Sportomatic Sunroof Coupe (with an 8-track player) |
uh...maybe pull the muffler?
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Stressed Member
I got at mine with an open end wrench. The fasteners you are refering to are sheet metal bolts, so they are easy to turn once loose. Perhaps yours are rusted. Good luck, and keep trying!
-Scott
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
Warren Hall Student
You might try loosening the left and right bumpers a little bit to give you a little room to work with.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
You do not have permissi
Try 1/4 in drives with wobbly extensions, also you might want to replace them with allens for ease.
