}{arlequin's Avatar
3rd brake light wiring... help
To all the electrical gurus out there,
I've wired an LED 3rd brake lamp to the infamous black wire w/ yellow stripe. It lights up fine when I step on the brakes, but then it also stays "on" when I turn on my headlights. If I tapped the wrong wire, why would it light up when I step on the brakes? Is there another wire in the tail lamp assembly that gets power just from hittting the brake pedal?
Could it be a bad grounding that causes this? Any other wire options that were used for the brake light? Previous owner might have changed the wiring...
dave
1973,5
Old 09-01-2003, 10:41 AM
D idn't E arn I t
RANDY P's Avatar
are you grounded straight to metal or to another wire showing ground - w/ lights off? If so -What happens when you step on the brakes AND the lights are on? If the 3rd brakelight shuts off, then that's your problem.
Start over. Take a plain old testlight, grounded to metal and verify you have the right wire, shoot the ground to metal and it should work. Yellow / black is what I used, it's fine on my 81.
rjp
In the movies only bad guys sleep in king size beds.
Old 09-01-2003, 11:02 AM
