thanks, when I contact them how do I explaing the fitting? Is it simply a high pressure fitting?
Chances are they can reuse the undamaged half. They will then look in their parts for the replacement to the other (damaged) part and weld them together (if they do not have the complete part in stock). Here in the states, I did this to make the fitting to adapat a later fuel filter to my car. Cost here was $12for the new fitting and welding it to the usable half of my fitting. |
thanks, I will take a look around.
So you are finally getting into it, hm? Good job. And always do the tranny and engine together for a drop. I don't understand how someone could think up this partial drop of the engine alone.
It's painfull enough to mate the tranny with the engine while both are out of the car. I don't even want to think about it with the tranny in the car. Today I threw in new torsion bars and adjustable spring plates into mine. 29 hollows and 21 solids. Also upgraded the front sway bar. Turbo tie rods and brackets for the rear sway bar are on its way from our host. It's finally handling a lot better. Once I get the shocks revalved and the rear torsion bar mounted it should be good for some track action. Ingo |
| All times are GMT -8. The time now is 01:13 PM. |
