perma tune question
should the perma tune cdi unit make the same high pitch whining noise as the stock unit?
thanks,
dlg
Old 08-03-2003, 02:51 PM
Cool
my 3 pin model never whined that I could hear.. Warren said you could hear a whine with a sound probe...........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-03-2003, 03:08 PM
Crusty Conservative
silverc4s's Avatar
Heard somewhere they made a kind of sucking sound...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 08-03-2003, 03:17 PM
350HP930's Avatar
My permatune is silent for all I can tell, then again the rear fuel pump in my 930 makes quite a bit of noise that is hard to compete with.
Old 08-03-2003, 03:18 PM
Early_S_Man's Avatar
Porsche Crest
The early blue-anodized Permatunes did whine just like the Bosch CDI-units, but the latest-model, clear-anodized units are potted internally with epoxy ... and the sound is muted considerably, though a mechanic's stethoscope can still reveal the normal operation of the DC-to-DC inverter oscillations.
There are several failure modes for the Permatune units ... not related to the DC-to-DC inverter! Some are heat-related, as Ron can attest ...
A good Tektronix oscilloscope is the best troubleshooting tool for CDI & Permatune testing ... though a Sun Analyzer at a shop is a good tool for gleaning whether ignition performance is up to snuff, too.
All electrical system parameters must be normal ... before CDI-systems can be narrowed down as the culprit. That means good, clean grounds at the battery, relay/fuse/CDI panel, alternator, and transaxle ... are a prerequisite!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-03-2003, 03:25 PM
