mrizvi66's Avatar
Send a message via Skype™ to mrizvi66
druck pressure
When i'm at idle the druck pressure needle keeps jumping from 2 to 5 constantly. What could be causing the needle to keep jumping?
1980 911SC
Old 08-03-2003, 10:09 AM
Tim L's Avatar
bad connection at the sender
Tim
Old 08-03-2003, 10:24 AM
Yep, like Tim said, bad connection or bad sender.
Old 08-03-2003, 10:26 AM
Early_S_Man's Avatar
Porsche Crest
Check for a loose or dirty Faston connector at the sender. The connector should be snug on the tab terminal, and not the least bit loose. After cleaning with Brakleen or isopropyl alcohol, if the connector is loose ... you can crimp the sides of the female Faston with needle-nose pliers, SLIGHTLY! You don't want to close the gap on both sides ... just reduce the gap and provide more holding tension!
Another possibility is the 14-pin connector on the relay and CDI panel on the left side of the engine compartment. Clean the pins very carefully with isopropyl alcohol and a bristle brush ... the pins are silver-plated brass, and the plating is very thin.
If it isn't the connection, sender or gauge defects could be the problem.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-03-2003, 10:35 AM
mrizvi66's Avatar
Cool I'll check it out when I get home.
Thanks Guys
1980 911SC
Old 08-03-2003, 12:50 PM
MAS MAS is offline
And the exact location of the sender is?
(thanks!)
-MAS
77 911S Targa (current car)
87 924S (my previous car)
Old 08-03-2003, 12:55 PM
350HP930's Avatar
Its by the crank pulley on most cars. It looks like a 1.5" X 1.5" cylinder with a wire running to it. There may also be a rubber cap over it.
Old 08-03-2003, 12:58 PM
Randy Webb's Avatar
Almost certain to be too much pressure on the druck. Install the electronic druck bypass control valve to keep the dreck out of the druck, lowering the pressure. Also replace all the rubber druck hoses on the car.
Old 08-03-2003, 01:36 PM
Glasgow 911SC's Avatar
FWIW isn't druck just the german word for pressure?
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 08-04-2003, 09:30 AM
Friend of Warren
Does anyone ever do searches on here?
Kurt V
Old 08-04-2003, 09:32 AM
HarryD's Avatar
No Kurt, we prefer to keep asking the same questions to see if you old timers have started becoming senile yet
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-04-2003, 10:03 AM
